[gdal-dev] Notice: issue about multi-threaded GTiff compression+decompression
Kurt Schwehr schwehr at gmail.com
Mon Oct 16 09:12:52 PDT 2023
> In short: multithreading is hard
So true! With the introduction of tsan things are a little less bad, but
tsan is still a tool with plenty of false positives and false negatives.
And that assumes that a particular issue is covered by the tests being run
under tsan.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231016/147135d6/attachment.htm>
