[gdal-dev] GDALPolygonize fails with "failed to execute insert : disk I/O error"
Shayan Ghofrany shayanghofrany at gmail.com
Tue Oct 17 08:52:11 PDT 2023
I'm attempting to polygonize a GeoTIFF using the built-in GDALPolygonize,
but sometimes it fails to write to file. I'm not attempting any sort of
multi-threaded functionality so everything is running synchronously. Here
is the code I'm using to polygonize:
https://gist.github.com/Irantwomiles/c5f38b3e81fc3014be4e859048ad523f
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231017/8994cb6a/attachment.htm>
