[gdal-dev] Driver for ISOXML format
Andreas Oxenstierna andreas.oxenstierna at t-kartor.com
Wed Oct 25 03:23:12 PDT 2023
Hello
I fully agree with the use case.
Note though that many of the content types are vendor-specific as defined in the ISO11783 ISO 11783-11 online data base.
ISOXML is a major misnomer as the data is binary.
There is a QGIS plugin GeoDataFarm which may be used as a starting point.
Best Regards / Vänliga hälsningar
Andreas Oxenstierna
Senior Strategic Advisor
+46 733 206 831<tel:%20+46733206831>
andreas.oxenstierna at t-kartor.com<mailto:andreas.oxenstierna at t-kartor.com>
connect on Linkedin<https://www.linkedin.com/in/andreas-oxenstierna-52876325/>
[cid:996E14871A0B48E6A28ECE0A1CF8F355]
T-Kartor Geospatial AB
Olof Mohlins väg 12
291 62 Kristianstad
<www.t-kartor.com>
t-kartor.com<www.t-kartor.com>
+46 44 206 800<tel:%20+4644206800>
info at t-kartor.com<mailto:info at t-kartor.com>
This e-mail is private and confidential between the sender and the addressee. In the event of misdirection, the recipient is prohibited from using, copying or disseminating it or any information in it. Please notify the above of any such misdirection.
On 25 Oct 2023, 11:57 +0200, Rahkonen Jukka via gdal-dev <gdal-dev at lists.osgeo.org>, wrote:
Because it is XML I would first try what the GMLAS driver https://gdal.org/drivers/vector/gmlas.htmlcan can get out of it.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Matthias Loeks via gdal-dev
Lähetetty: keskiviikko 25. lokakuuta 2023 12.41
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] Driver for ISOXML format
Hello all,
apologies if this has been asked before - I couldn't find anything, but might have missed past messages.
Does anyone know if someone ever considered implementing a GDAL driver for the ISOXML format used in Digital Agriculture / Precision Farming?
It would be very useful to support it in GDAL, so both GIS software and Farm Management Information Systems (FMIS) could much more easily integrate it, offering read/write support.
To my knowledge, there is no standardized support for this as of today. However, even though ISOXML has been around for a while, it is an established industry standard, and widely used throghout the growing Smart Farming community.
I am a software engineer and would be willing to work on a driver, even though I'm not familiar with GDAL core code at all so far. Anyone who would be interested in joining? My employer might offer options for funding.
Many thanks for your input!
Best regards,
Matthias
Further reading
. https://www.iso.org/standard/61581.html
. https://www.isobus.net/isobus/
. https://www.dev4agriculture.de/en/isoxml-library/
. https://gis.stackexchange.com/questions/354092/converting-geojson-to-isoxml-isobus-iso-11783-10
. https://github.com/aparshin/isoxml-visualization
. https://adaptframework.org/ (working on standardizing agricultural data flows)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231025/cfc2f039/attachment-0001.htm>
Type: image/png
Desc: 996E14871A0B48E6A28ECE0A1CF8F355.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231025/cfc2f039/attachment-0001.png>
