[gdal-dev] SICD driver
Even Rouault even.rouault at spatialys.com
Tue Sep 5 00:24:54 PDT 2023
SICD is a specification over NITF for which there is a GDAL driver :
https://gdal.org/drivers/raster/nitf.html
There have been tunings a couple years ago to deal with SICD apparently:
https://github.com/OSGeo/gdal/pull/4028
Even
Le 05/09/2023 à 02:29, ni hao a écrit :
> Hi list,
> Is there a GDAL sensor independent complex data (SICD) driver ?
> https://help.umbra.space/kb/guide/en/metadata-standard-sensor-independent-complex-data-sicd-0rG1v1c6mZ/Steps/665407
> Thank you.
> <https://help.umbra.space/kb/guide/en/metadata-standard-sensor-independent-complex-data-sicd-0rG1v1c6mZ/Steps/665407>
> Metadata Standard: Sensor Independent Complex Data (SICD) | Customer
> knowledge base
> IntroductionSICD is an open, standardized specification for SAR data
> developed and maintained by the US National Geospatial Intelligence
> Agency (NGA). The full documentation is available here.Unlike CPHD,
> SICD files have been processed through an "image formation algorithm"
> and associated metadata has been adapted to meet a generic level of
> "independence" from the sensor that generated it. Therefore, while
> SICD files are more "opinionated" than CPHD, they are also less
> idiosyncratic.The NGA's motivation for creating the SICD standard was
> to enable integration of data from multiple disparate SAR systems
> using a common processing toolset and downstream analytical workflow.
> As more commercial providers adopt the SICD standard, end-users will
> benefit from the ability to create generic tools rather than having to
> build custom plugins for every vendor.Umbra uses the SICD standard to
> provide complex phase data in a more refined state than it does with
> its CPHD product. The "Polar Format Algorithm" (PFA) is used for
> help.umbra.space
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230905/25ec5157/attachment.htm>
