[gdal-dev] SICD driver
ni hao ni_hao88 at hotmail.com
Mon Sep 4 17:29:41 PDT 2023
Hi list,
Is there a GDAL sensor independent complex data (SICD) driver ?
https://help.umbra.space/kb/guide/en/metadata-standard-sensor-independent-complex-data-sicd-0rG1v1c6mZ/Steps/665407
Thank you.
[https://stonly.com/resources/facebook-cover.jpg]<https://help.umbra.space/kb/guide/en/metadata-standard-sensor-independent-complex-data-sicd-0rG1v1c6mZ/Steps/665407>
Metadata Standard: Sensor Independent Complex Data (SICD) | Customer knowledge base<https://help.umbra.space/kb/guide/en/metadata-standard-sensor-independent-complex-data-sicd-0rG1v1c6mZ/Steps/665407>
IntroductionSICD is an open, standardized specification for SAR data developed and maintained by the US National Geospatial Intelligence Agency (NGA). The full documentation is available here.Unlike CPHD, SICD files have been processed through an "image formation algorithm" and associated metadata has been adapted to meet a generic level of "independence" from the sensor that generated it. Therefore, while SICD files are more "opinionated" than CPHD, they are also less idiosyncratic.The NGA's motivation for creating the SICD standard was to enable integration of data from multiple disparate SAR systems using a common processing toolset and downstream analytical workflow. As more commercial providers adopt the SICD standard, end-users will benefit from the ability to create generic tools rather than having to build custom plugins for every vendor.Umbra uses the SICD standard to provide complex phase data in a more refined state than it does with its CPHD product. The "Polar Format Algorithm" (PFA) is used for
help.umbra.space
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230905/a5de43f7/attachment.htm>
