[gdal-dev] PROJ_DATA/PROJ_LIB set during build time for python bindings?
Even Rouault even.rouault at spatialys.com
Mon Sep 4 00:03:32 PDT 2023
A default PROJ_DATA value is "burnt" into libproj at its build time. Its
value evaluates to "${CMAKE_INSTALL_FULL_DATADIR}/proj"
Similarly for GDAL_DATA which evaluates to
"${CMAKE_INSTALL_PREFIX}/${CMAKE_INSTALL_DATADIR}/gdal"
Even
Le 04/09/2023 à 06:53, Ryan Yang a écrit :
> Hi!
> I see that PROJ_DATA is an env variable to be set for pointing to the
> directory containing proj.db. However, I was wondering if there's a
> way to configure this to be set during build time via some cmake arg
> or if this was intended to be a dynamic env variable that can always
> change?
> Asking because currently building gdal python bindings for bazel, but
> it seems to require an env set for PROJ_LIB/PROJ_DATA whenever I'm
> importing gdal.
> Thanks in advance!
> Ryan
> This email may be confidential and/or privileged. If you received this
> communication by mistake, please don't forward it to anyone else,
> delete all copies and attachments, and let me know that it has gone to
> the wrong person.
> Statements made above may reflect a potential business arrangement.
> Any such statements are provided solely as a basis for further
> discussion, and are not intended to be and do not constitute a legally
> binding obligation. No legally binding obligations will be created,
> implied, or inferred until an agreement is duly executed in writing by
> all parties.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230904/e1bc4383/attachment.htm>
