[gdal-dev] Call for discussion/review of RFC95: Use standard C/C++ integer types
Even Rouault even.rouault at spatialys.com
Tue Sep 19 09:30:00 PDT 2023
No other reaction ? Are people comfortable with bumping to 4.0 ? If so,
no opinion on what we should slip in while we are it (thinking more
about breaking changes than new features, which generally can be added
afterwards) ?
Le 16/09/2023 à 14:53, Even Rouault a écrit :
>> About GDAL 4.0 vs 3.8, I'm fine with 4.0. But I do not know if
>> "users" will expect a bigger change in functionalities for a mayor
>> release update.
> Yes, there are a few other tickets flagged as appropriate for 4.0:
> https://github.com/OSGeo/gdal/milestone/33
> All of them could probably be implemented without making the 3.8/4.0
> schedule drift. The exportToWKT with WKT2 as default would involve
> some work in GDAL drivers, given that some of them are dependent on
> WKT1, but hopefully nothing that cannot be overcome. The main impact
> would probably be on the autotest suite (fast resolution would be
> similar to drivers, and replace all exportToWKT() with
> exportToWKT(["FORMAT=WKT1"]), and possibly switch progressively to WKT2)
> Other topics that could/should be split for a 4.0 ?
> Thinking about CRS stuff, currently gdaltransform operates with the
> GIS friendly axis order, which is at odds with the fact that
> OGRSpatialReference default and PROJ's cs2cs which use the authority
> compliant axis order since PROJ 6.0 / GDAL 3.0. Not sure if we'd want
> to make gdaltransform follow cs2cs (possibly with a
> --axis-order=gis_friendly/authority_compliant explicit flag)
> Maybe some 'Ex' (which stands for API) functions in the C API could be
> removed and their extra/modified arguments reincorporated with the
> original non-Ex function. Would totally make sense for the few ones
> impacted by RFC95 like GDALGetDefaultHistogramEx,
> GDALSetDefaultHistogramEx, GDALGetRasterHistogramEx
> There might be also some defaults (open, creation options) that could
> be changed, although nothing immediately jumps to mind
> Even
http://www.spatialys.com
