[gdal-dev] adding metadata -mo in a domain?
Even Rouault even.rouault at spatialys.com
Tue Sep 19 17:19:26 PDT 2023
Not from cli. From the API, it is dataset.SetMetadataItem(key, value,
domain)
Le 20/09/2023 à 02:14, Michael Sumner a écrit :
> When we add metadata with -mo can we somehow specify the DOMAIN it
> would be added to, or be instantiated with?
> gdal_translate gcore/data/float32.tif /tmp/add_md.vrt -mo PHONY=important
> I would like to tweak that so that the item was in a new domain, i.e.
>   <Metadata>
>     <MDI key="AREA_OR_POINT">Area</MDI>
>   </Metadata>
>   <Metadata domain="IMAGE_STRUCTURE">
>     <MDI key="INTERLEAVE">BAND</MDI>
>   </Metadata>
>   <Metadata domain="MY_NEW_DOMAIN">
>     <MDI key="PHONY">important</MDI>
>   </Metadata>
> Is that possible from cli?
> Thank you
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230920/c099cfdf/attachment.htm>
