[gdal-dev] adding metadata -mo in a domain?
Michael Sumner mdsumner at gmail.com
Tue Sep 19 17:32:10 PDT 2023
Thanks Even,  could add a  AttachDomainMetadata here that expected "-dmo
DOMAIN:META-TAG=VALUE"
https://github.com/OSGeo/gdal/blob/a4b57c22606be2258196a933d310f301e3ece93f/apps/gdal_translate_lib.cpp#L2625
I'll try that, or is it too much over-reach?
Ultimately it's for vrt:// con so could do
vrt://{dsn}?dmo=DOMAIN:META-TAG=VALUE
Cheers, Mike
On Wed, Sep 20, 2023 at 10:19 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Not from cli. From the API, it is dataset.SetMetadataItem(key, value,
> domain)
> Le 20/09/2023 à 02:14, Michael Sumner a écrit :
> When we add metadata with -mo can we somehow specify the DOMAIN it would
> be added to, or be instantiated with?
> gdal_translate gcore/data/float32.tif /tmp/add_md.vrt -mo PHONY=important
> I would like to tweak that so that the item was in a new domain, i.e.
>   <Metadata>
>     <MDI key="AREA_OR_POINT">Area</MDI>
>   </Metadata>
>   <Metadata domain="IMAGE_STRUCTURE">
>     <MDI key="INTERLEAVE">BAND</MDI>
>   </Metadata>
>   <Metadata domain="MY_NEW_DOMAIN">
>          <MDI key="PHONY">important</MDI>
>   </Metadata>
> Is that possible from cli?
> Thank you
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Michael Sumner
Hobart, Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230920/872082d1/attachment.htm>
