[gdal-dev] adding metadata -mo in a domain?
Even Rouault even.rouault at spatialys.com
Wed Sep 20 01:40:23 PDT 2023
Sounds OK to me
Le 20/09/2023 à 02:32, Michael Sumner a écrit :
> Thanks Even,  could add a  AttachDomainMetadata here that expected
> "-dmo DOMAIN:META-TAG=VALUE"
> https://github.com/OSGeo/gdal/blob/a4b57c22606be2258196a933d310f301e3ece93f/apps/gdal_translate_lib.cpp#L2625
> I'll try that, or is it too much over-reach?
> Ultimately it's for vrt:// con so could do
> vrt://{dsn}?dmo=DOMAIN:META-TAG=VALUE
> Cheers, Mike
> On Wed, Sep 20, 2023 at 10:19 AM Even Rouault
> <even.rouault at spatialys.com> wrote:
>     Not from cli. From the API, it is dataset.SetMetadataItem(key,
>     value, domain)
>     Le 20/09/2023 à 02:14, Michael Sumner a écrit :
>>     When we add metadata with -mo can we somehow specify the DOMAIN
>>     it would be added to, or be instantiated with?
>>     gdal_translate gcore/data/float32.tif /tmp/add_md.vrt -mo
>>     PHONY=important
>>     I would like to tweak that so that the item was in a new domain,
>>     i.e.
>>       <Metadata>
>>         <MDI key="AREA_OR_POINT">Area</MDI>
>>       </Metadata>
>>       <Metadata domain="IMAGE_STRUCTURE">
>>         <MDI key="INTERLEAVE">BAND</MDI>
>>       </Metadata>
>>       <Metadata domain="MY_NEW_DOMAIN">
>>              <MDI key="PHONY">important</MDI>
>>       </Metadata>
>>     Is that possible from cli?
>>     Thank you
>>     Michael Sumner
>>     Software and Database Engineer
>>     Australian Antarctic Division
>>     Hobart, Australia
>>     e-mail: mdsumner at gmail.com
>>     _______________________________________________
>>     gdal-dev mailing list
>>     gdal-dev at lists.osgeo.org
>>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
>     http://www.spatialys.com
>     My software is free, but my time generally not.
> Michael Sumner
> Hobart, Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230920/ec8c0c46/attachment-0001.htm>
