[gdal-dev] GeoTIFF and concurrent block reads
Laurențiu Nicola lnicola at dend.ro
Thu Sep 21 06:38:36 PDT 2023
Hello,
GDAL 3.6 added support for multi-threaded reading using PRead, but I couldn't spot ReadBlock using the same code path. On the other hand, I didn't see it taking a lock either, so I'm a little confused :-). My question is whether ReadBlock supports concurrent reads or not (*).
(*) I think these can also be implemented at VSI level by wrapping a file handle and turning Seek + Read into a PRead (when supported), even for drivers that don't explicitly support PRead.
Thanks,
Laurentiu
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230921/2cb6bec9/attachment-0001.htm>
