[gdal-dev] GeoTIFF and concurrent block reads
Even Rouault even.rouault at spatialys.com
Thu Sep 21 07:02:14 PDT 2023
Laurentiu,
> GDAL 3.6 added support for multi-threaded reading using PRead, but I
> couldn't spot ReadBlock using the same code path.
If you read one single block at a time, the multi-threaded optimization
cannot kick in, since the elementary decoding unit is a block. You must
call RasterIO() with a window intersecting several block.
> (*) I think these can also be implemented at VSI level by wrapping a
> file handle and turning Seek + Read into a PRead (when supported),
> even for drivers that don't explicitly support PRead.
The multi-threaded optimization also works for VSI file systems not
supported PRead(), but doing what you mention above: doing Seek+Read
under a lock. This is of course less efficient.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230921/48d8b845/attachment.htm>
