[gdal-dev] layer.GetSpatialRef() fails on linux for shapefiles
Jonathan Moules jonathan-lists at lightpear.com
Sun Sep 24 14:22:51 PDT 2023
 > Also check if the environment isn't messed up regarding PROJ and the
PROJ_LIB/PROJ_DATA environment variable
Thanks Even; sorry, what does this line mean? I'm guessing you're
referring to: https://proj.org/en/9.3/usage/environmentvars.html - what
would a "messed up" one look like?
Thanks,
Jonathan
On 2023-09-21 13:39, Even Rouault via gdal-dev wrote:
> Run ogrinfo on one shapefile to see if some more interesting error
> message is displayed
> Le 21/09/2023 à 14:34, Jonathan Moules via gdal-dev a écrit :
>> Yeah, I'm afraid the error message is pretty much non-existent:
>>     Traceback (most recent call last):
>>       File
>>     "/home/name/Code/DSHub/PoC/Extract-Transform-Load-POC/Metadata/AME/src/info_vector.py",
>>     line 119, in get_layer_metadata
>>         tmp_projection = layer.GetSpatialRef()
>>       File
>>     "/home/name/anaconda3/envs/AME_env/lib/python3.11/site-packages/osgeo/ogr.py",
>>     line 1990, in GetSpatialRef
>>         return _ogr.Layer_GetSpatialRef(self, *args)
>>     RuntimeError
>> Suggestions welcome.
>> On 18/09/2023 12:51, Javier Jimenez Shaw wrote:
>>> Hi Jonathan
>>> Which exact RuntimeError are you getting? It can be for several
>>> reasons (probably an installation or configuration issue).
>>> Best,
>>> Javier
>>> On Mon, 18 Sept 2023 at 11:06, Jonathan Moules
>>> <jonathan-lists at lightpear.com> wrote:
>>>     Hi List,
>>>     I'm trying to get vector layer information via OGR and Python:
>>>     This works fine for me on Windows with GDAL 3.7.1 on various
>>>     different
>>>     types of files (Shapefile, GPKG, GML, KML, GDB).
>>>     But for my colleague on Ubuntu 22.0.4.3, also on GDAL 3.7.1 (via
>>>     Conda),
>>>     they get a Python RuntimeError for all shapefiles (the exact same
>>>     shapefiles that work fine for me). It works for Geopackages for
>>>     them.
>>>     Anyone have any thoughts?
>>>     Thanks,
>>>     Jonathan
>>>     _______________________________________________
>>>     gdal-dev mailing list
>>>     gdal-dev at lists.osgeo.org
>>>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230924/9d5d45b7/attachment.htm>
