[gdal-dev] layer.GetSpatialRef() fails on linux for shapefiles
Even Rouault even.rouault at spatialys.com
Sun Sep 24 14:35:06 PDT 2023
Le 24/09/2023 à 23:22, Jonathan Moules via gdal-dev a écrit :
> > Also check if the environment isn't messed up regarding PROJ and the
> PROJ_LIB/PROJ_DATA environment variable
> Thanks Even; sorry, what does this line mean? I'm guessing you're
> referring to: https://proj.org/en/9.3/usage/environmentvars.html -
> what would a "messed up" one look like?
Hard to say without access to the machine. Perhaps just try to recreate
a new Conda env from scratch
http://www.spatialys.com
