[gdal-dev] layer.GetSpatialRef() fails on linux for shapefiles
Jonathan Moules jonathan-lists at lightpear.com
Sun Sep 24 14:37:30 PDT 2023
Thanks Even. I don't have access to the machine either as the colleague
is moving to another project. I'll have to see if it fails for another
*nix user.
On 2023-09-24 22:35, Even Rouault wrote:
> Le 24/09/2023 à 23:22, Jonathan Moules via gdal-dev a écrit :
>> > Also check if the environment isn't messed up regarding PROJ and
>> the PROJ_LIB/PROJ_DATA environment variable
>> Thanks Even; sorry, what does this line mean? I'm guessing you're
>> referring to: https://proj.org/en/9.3/usage/environmentvars.html -
>> what would a "messed up" one look like?
> Hard to say without access to the machine. Perhaps just try to
> recreate a new Conda env from scratch
