[gdal-dev] layer.GetSpatialRef() fails on linux for shapefiles
Jan Heckman jan.heckman at gmail.com
Sun Sep 24 14:52:17 PDT 2023
Sorry to break in, but surely, we would like to see the .prj file in
question for a simple try at reproducing?
On Sun, Sep 24, 2023 at 11:37 PM Jonathan Moules via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Thanks Even. I don't have access to the machine either as the colleague
> is moving to another project. I'll have to see if it fails for another
> *nix user.
> On 2023-09-24 22:35, Even Rouault wrote:
> > Le 24/09/2023 à 23:22, Jonathan Moules via gdal-dev a écrit :
> >> > Also check if the environment isn't messed up regarding PROJ and
> >> the PROJ_LIB/PROJ_DATA environment variable
> >> Thanks Even; sorry, what does this line mean? I'm guessing you're
> >> referring to: https://proj.org/en/9.3/usage/environmentvars.html -
> >> what would a "messed up" one look like?
> > Hard to say without access to the machine. Perhaps just try to
> > recreate a new Conda env from scratch
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230924/a59900be/attachment.htm>
