[gdal-dev] About installing EXPAT
Even Rouault even.rouault at spatialys.com
Mon Sep 25 05:29:52 PDT 2023
Abel,
> In Cmakefile.txt of the project I’ve configured this (below #
> Developer may want to specify some variable to find proper version.):
> set(EXPAT_INCLUDE_DIR "D:/GitHub-repository/libexpat/expat/lib")
> set(EXPAT_LIBRARY
> "D:/GitHub-repository/libexpat/expat/build/Debug/libexpatd.lib")
Is this .lib a static library, or an import library of the .dll ? My
assumption (I may be wrong) is that it is an import lib of the .dll. In
which case you must not set EXPAT_USE_STATIC_LIBS
> set(EXPAT_LIBRARY
> "D:/GitHub-repository/libexpat/expat/build/Debug/libexpatd.dll")
That won't work. This needs to be a .lib
You'd better run cmake again on expat with a
-DCMAKE_INSTALL_PREFIX=d:/install-prefix   and run "cmake --build .
--target install", and then when building GDAL, use "cmake ..
-DCMAKE_PREFIX_PATH=d:/install-prefix", so it automatically configures
things from what is found in d:/install-prefix
You could also potentially use vcpkg or conda to install GDAL
dependencies instead of building them from scratch:
https://gdal.org/download.html
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230925/b66646be/attachment.htm>
