[gdal-dev] About installing EXPAT
Abel Pau a.pau at creaf.uab.cat
Mon Sep 25 07:21:11 PDT 2023
Hi Even,
I really appreciate your help.
I prefer going by the easy way so once installed miniconda and applied all the described in download.htm.
To have the EXPAT installed I do that: conda install expat
And the, when I try the cmake .. some issues appear
D:\GitHub-repository\GDAL\build>cmake ..
-- Selecting Windows SDK version 10.0.19041.0 to target Windows 10.0.19045.
-- GDAL_VERSION          = 3.8.0dev
-- GDAL_ABI_FULL_VERSION = 38
-- GDAL_SOVERSION        =
-- Could NOT find MSSQL_NCLI (missing: MSSQL_NCLI_LIBRARY MSSQL_NCLI_INCLUDE_DIR MSSQL_NCLI_VERSION)
-- Could NOT find MSSQL_ODBC (missing: MSSQL_ODBC_LIBRARY MSSQL_ODBC_INCLUDE_DIR MSSQL_ODBC_VERSION)
-- Could NOT find MySQL (missing: MYSQL_LIBRARY MYSQL_INCLUDE_DIR)
-- Could NOT find CURL (missing: CURL_LIBRARY CURL_INCLUDE_DIR)
-- Could NOT find Iconv (missing: Iconv_LIBRARY Iconv_CHARSET_LIBRARY Iconv_INCLUDE_DIR)
-- Could NOT find LibXml2 (missing: LIBXML2_LIBRARY LIBXML2_INCLUDE_DIR)
-- Could NOT find EXPAT (missing: EXPAT_DIR)
-- Could NOT find EXPAT (missing: EXPAT_LIBRARY EXPAT_INCLUDE_DIR)
CMake Error at cmake/helpers/CheckDependentLibraries.cmake:202 (message):
  Configured to use EXPAT, but not found
Call Stack (most recent call first):
  cmake/helpers/CheckDependentLibraries.cmake:348 (gdal_check_package)
  gdal.cmake:265 (include)
  CMakeLists.txt:280 (include)
-- Configuring incomplete, errors occurred!
There is something I don’t understand because I don’t know what to do now.
Why after doing an gdal_master_env and installing everything and expat it doesn’t work?
Once again, I appreciate your help :)
De: Even Rouault <even.rouault at spatialys.com>
Enviado el: dilluns, 25 de setembre de 2023 14:30
Para: Abel Pau <a.pau at creaf.uab.cat>; gdal dev <gdal-dev at lists.osgeo.org>
Asunto: Re: [gdal-dev] About installing EXPAT
Abel,
In Cmakefile.txt of the project I’ve configured this (below # Developer may want to specify some variable to find proper version.):
set(EXPAT_INCLUDE_DIR "D:/GitHub-repository/libexpat/expat/lib")
set(EXPAT_LIBRARY "D:/GitHub-repository/libexpat/expat/build/Debug/libexpatd.lib")
Is this .lib a static library, or an import library of the .dll ? My assumption (I may be wrong) is that it is an import lib of the .dll. In which case you must not set EXPAT_USE_STATIC_LIBS
set(EXPAT_LIBRARY "D:/GitHub-repository/libexpat/expat/build/Debug/libexpatd.dll")
That won't work. This needs to be a .lib
You'd better run cmake again on expat with a -DCMAKE_INSTALL_PREFIX=d:/install-prefix   and run "cmake --build . --target install", and then when building GDAL, use "cmake .. -DCMAKE_PREFIX_PATH=d:/install-prefix", so it automatically configures things from what is found in d:/install-prefix
You could also potentially use vcpkg or conda to install GDAL dependencies instead of building them from scratch: https://gdal.org/download.html
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230925/8203448c/attachment-0001.htm>
