[gdal-dev] About installing EXPAT
Even Rouault even.rouault at spatialys.com
Mon Sep 25 07:31:31 PDT 2023
Add -DCMAKE_PREFIX_PATH="$CONDA_PREFIX" to your CMake invokation
(assuming your have activate your Conda environment, so CONDA_PREFIX is set)
My suggestion is inspired from our CI Conda based Windows build:
https://github.com/OSGeo/gdal/blob/7fc7bb59d2b2de1dca03dd18c14005f2b64adb49/.github/workflows/cmake_builds.yml#L463
You should also probably clear your existing CMakeCache.txt before doing
the abve, to avoid mixing with variables set from your previous experiments
Le 25/09/2023 à 16:21, Abel Pau a écrit :
> Hi Even,
> I really appreciate your help.
> I prefer going by the easy way so once installed miniconda and applied
> all the described in download.htm.
> To have the EXPAT installed I do that: conda install expat
> And the, when I try the cmake .. some issues appear
> D:\GitHub-repository\GDAL\build>cmake ..
> -- Selecting Windows SDK version 10.0.19041.0 to target Windows
> 10.0.19045.
> -- GDAL_VERSION          = 3.8.0dev
> -- GDAL_ABI_FULL_VERSION = 38
> -- GDAL_SOVERSION        =
> -- Could NOT find MSSQL_NCLI (missing: MSSQL_NCLI_LIBRARY
> MSSQL_NCLI_INCLUDE_DIR MSSQL_NCLI_VERSION)
> -- Could NOT find MSSQL_ODBC (missing: MSSQL_ODBC_LIBRARY
> MSSQL_ODBC_INCLUDE_DIR MSSQL_ODBC_VERSION)
> -- Could NOT find MySQL (missing: MYSQL_LIBRARY MYSQL_INCLUDE_DIR)
> -- Could NOT find CURL (missing: CURL_LIBRARY CURL_INCLUDE_DIR)
> -- Could NOT find Iconv (missing: Iconv_LIBRARY Iconv_CHARSET_LIBRARY
> Iconv_INCLUDE_DIR)
> -- Could NOT find LibXml2 (missing: LIBXML2_LIBRARY LIBXML2_INCLUDE_DIR)
> -- Could NOT find EXPAT (missing: EXPAT_DIR)
> -- Could NOT find EXPAT (missing: EXPAT_LIBRARY EXPAT_INCLUDE_DIR)
> CMake Error at cmake/helpers/CheckDependentLibraries.cmake:202 (message):
>   Configured to use EXPAT, but not found
> Call Stack (most recent call first):
> cmake/helpers/CheckDependentLibraries.cmake:348 (gdal_check_package)
>   gdal.cmake:265 (include)
>   CMakeLists.txt:280 (include)
> -- Configuring incomplete, errors occurred!
> There is something I don’t understand because I don’t know what to do now.
> *Why after doing an gdal_master_env and installing everything and
> expat it doesn’t work?*
> Once again, I appreciate your help :)
> *De:*Even Rouault <even.rouault at spatialys.com>
> *Enviado el:* dilluns, 25 de setembre de 2023 14:30
> *Para:* Abel Pau <a.pau at creaf.uab.cat>; gdal dev
> <gdal-dev at lists.osgeo.org>
> *Asunto:* Re: [gdal-dev] About installing EXPAT
> Abel,
>     In Cmakefile.txt of the project I’ve configured this (below #
>     Developer may want to specify some variable to find proper version.):
>     set(EXPAT_INCLUDE_DIR "D:/GitHub-repository/libexpat/expat/lib")
>     set(EXPAT_LIBRARY
>     "D:/GitHub-repository/libexpat/expat/build/Debug/libexpatd.lib")
> Is this .lib a static library, or an import library of the .dll ? My
> assumption (I may be wrong) is that it is an import lib of the .dll.
> In which case you must not set EXPAT_USE_STATIC_LIBS
>     set(EXPAT_LIBRARY
>     "D:/GitHub-repository/libexpat/expat/build/Debug/libexpatd.dll")
> That won't work. This needs to be a .lib
> You'd better run cmake again on expat with a
> -DCMAKE_INSTALL_PREFIX=d:/install-prefix   and run "cmake --build .
> --target install", and then when building GDAL, use "cmake ..
> -DCMAKE_PREFIX_PATH=d:/install-prefix", so it automatically configures
> things from what is found in d:/install-prefix
> You could also potentially use vcpkg or conda to install GDAL
> dependencies instead of building them from scratch:
> https://gdal.org/download.html
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230925/3f6cf510/attachment.htm>
