[gdal-dev] layer.GetSpatialRef() fails on linux for shapefiles
Jonathan Moules jonathan-lists at lightpear.com
Thu Sep 28 04:10:28 PDT 2023
Hi Even,
The colleague doesn't have either a PROJ_LIB or a PROJ_DATA environment
variable.
I asked another colleague to try it; they're on Ubuntu 20.04, and it
worked for them. I believe using the same setup instructions.
Cheers,
Jonathan
On 2023-09-24 22:37, Jonathan Moules via gdal-dev wrote:
> Thanks Even. I don't have access to the machine either as the
> colleague is moving to another project. I'll have to see if it fails
> for another *nix user.
> On 2023-09-24 22:35, Even Rouault wrote:
>> Le 24/09/2023 à 23:22, Jonathan Moules via gdal-dev a écrit :
>>> > Also check if the environment isn't messed up regarding PROJ and
>>> the PROJ_LIB/PROJ_DATA environment variable
>>> Thanks Even; sorry, what does this line mean? I'm guessing you're
>>> referring to: https://proj.org/en/9.3/usage/environmentvars.html -
>>> what would a "messed up" one look like?
>> Hard to say without access to the machine. Perhaps just try to
>> recreate a new Conda env from scratch
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
