[gdal-dev] layer.GetSpatialRef() fails on linux for shapefiles
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Thu Sep 28 04:37:27 PDT 2023
Then they should add that environment if they do not know that they do not belong to "most users" https://proj.org/en/9.3/usage/environmentvars.html
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Jonathan Moules via gdal-dev
Lähetetty: torstai 28. syyskuuta 2023 14.10
Vastaanottaja: gdal-dev at lists.osgeo.org; Even Rouault <even.rouault at spatialys.com>
Aihe: Re: [gdal-dev] layer.GetSpatialRef() fails on linux for shapefiles
Hi Even,
The colleague doesn't have either a PROJ_LIB or a PROJ_DATA environment variable.
I asked another colleague to try it; they're on Ubuntu 20.04, and it worked for them. I believe using the same setup instructions.
Cheers,
Jonathan
On 2023-09-24 22:37, Jonathan Moules via gdal-dev wrote:
> Thanks Even. I don't have access to the machine either as the
> colleague is moving to another project. I'll have to see if it fails
> for another *nix user.
> On 2023-09-24 22:35, Even Rouault wrote:
>> Le 24/09/2023 à 23:22, Jonathan Moules via gdal-dev a écrit :
>>> > Also check if the environment isn't messed up regarding PROJ and
>>> the PROJ_LIB/PROJ_DATA environment variable
>>> Thanks Even; sorry, what does this line mean? I'm guessing you're
>>> referring to:
>>> https://proj.org/en/9.3/usage/environmentvars.html - what would a "messed up" one look like?
>> Hard to say without access to the machine. Perhaps just try to
>> recreate a new Conda env from scratch
> gdal-dev mailing list
> https://list/
> s.osgeo.org%2Fmailman%2Flistinfo%2Fgdal-dev&data=05%7C01%7Cjukka.rahko
> nen%40maanmittauslaitos.fi%7C1f6517888cb34fa40aed08dbc01389dd%7Cc4f8a6
> 3255804a1c92371d5a571b71fa%7C0%7C0%7C638314962370381350%7CUnknown%7CTW
> FpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6
> Mn0%3D%7C3000%7C%7C%7C&sdata=3fVru6K6Ndpkv35FnAbMOlT%2BM96USO7wywqx550
> uRUs%3D&reserved=0
https://lists.osgeo.org/mailman/listinfo/gdal-dev
