[gdal-dev] GDAL version in pip requirements file
Kurt Schwehr schwehr at gmail.com
Thu Sep 28 09:10:43 PDT 2023
I am not sure if there is anything in this, but take a look at
https://packaging.python.org/en/latest/guides/
Also, I might suggest avoiding command line solutions. You can get the
version from the python module
On Mon, Sep 25, 2023, 11:55 PM Luca Delucchi via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi everyone,
> I would like to know if it is possible to set GDAL version in the pip
> requirements file using gdal-config of the machine running the
> installation, I tried some different ways but I was not able to do it,
> also leaving GDAL without any specified version doesn't work because
> it takes the last python GDAL version available in that system.
> Do you have any advice?
> ciao
> Luca
> www.lucadelu.org
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230928/7ef774d0/attachment.htm>
