[gdal-dev] GDAL version in pip requirements file
Luca Delucchi lucadeluge at gmail.com
Thu Sep 28 07:56:51 PDT 2023
Il mar 26 set 2023, 09:07 Stefan Blumentrath <Stefan.Blumentrath at gmx.de> ha
scritto:
> Hi Luca,
Hi Stefan,
> You could parse the gdal config version output into an environment
> variable and then specify the version in requirements.txt like this:
> GDAL==${GDAL_VERSION}
Thanks a lot it looks a good solution
> Cheers,
> Stefan
Best
Luca
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230928/bd737191/attachment-0001.htm>
