[gdal-dev] Using ogr2ogr with limited memory
Michael Sumner mdsumner at gmail.com
Fri Sep 29 04:58:16 PDT 2023
what's the task? what about batching the geometry and or fields? can you
run on just the first feature, does that work?
how many features, how big is the task?
On Wed, 27 Sept 2023, 13:16 Scott via gdal-dev, <gdal-dev at lists.osgeo.org>
wrote:
> Any tips for using ogr2ogr to use only a specified amount of RAM? I'm
> not having any luck.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230929/fd1f5822/attachment.htm>
