[gdal-dev] discussion on xarray and the missing abstract-grid specification
Michael Sumner mdsumner at gmail.com
Wed Apr 3 15:03:59 PDT 2024
ah thanks Even, I understand that and it was the first example that Ryan
acknowledged was a problem a while back - he'd seen the Float32 problem in
GHRSST. Excellent to get your take and the details.
I've written up a small description of how this affects GHRSST, and my
still-undecided next step to fix it (as COGs).
https://gist.github.com/mdsumner/66aac8e54b54faa24e14b63f396dca32
(this was going to be part of my pitch to xarray and now I don't need so
much extra background to make the point).
I'm keen to collate examples if people have good ones, I have plenty though
Cheers, Mike
On Thu, 4 Apr 2024, 08:26 Even Rouault, <even.rouault at spatialys.com> wrote:
> Hi,
> Not that I've a strong opinion on what GeoZarr/XArray should do, but yes
> 1D coordinate arrays are a bit of a pain to deal with, when they actually
> just encode a regularly spaced grid. This is something I've hit in the
> bridge between the GDAL multidimensional API (roughly netCDF based) and the
> GDAL "classic" 2D raster API, when you want to expose a view of a multi-dim
> dataset as a classic one. There's this bit of logic in
> https://github.com/OSGeo/gdal/blob/master/gcore/gdalmultidim.cpp#L7334 to
> guess if the 1D coordinate array is regularly spaced or not. The netCDF
> driver has a similar heuristics too. This is quite error prone, especially
> if Float32 coordinates are used. There it can be difficult to detect if it
> is a regularly spaced array but Float32 hasn't sufficient precision to
> fully encode it, or if it there are genuine irregularities in the spacing.
> For Float64, the precision issues are less a practical error, because
> comparing the expected value (assuming a regular spacing) with the one of
> the 1D coordinate array with a very small relative epsilon, like 1e-8, is
> sufficient.
> Even
> Le 03/04/2024 à 22:56, Michael Sumner via gdal-dev a écrit :
> Here's an (ahem) extremely important discussion on the prospects for
> xarray to extend from the coordinates-only model (like that of netcdf) for
> geo reference:
> https://discourse.pangeo.io/t/example-which-highlights-the-limitations-of-netcdf-style-coordinates-for-large-geospatial-rasters/
> I'm heartened to see this recognized at this level. I think GDAL per se
> should feature in this discussion prominently, and not just the downstream
> Python packages that are mentioned.
> For my input, I'll be highlighting examples of
> -  degenerate rectilinear coordinates, and the problem of whether to
> assign a regular grid there (with a trivial lightweight Translate a la
> -a_ullr), or to define a new regular grid and push it through the Warp api,
> as a dataset that picks up or can be pointed to the 1D coordinate arrays.
> This has been the crux of the issue for me, I get to decisions where it's
> not clear what was intended or what should be done going forward.
> - actual curvilinear coordinates, and the very very general power of that
> to resolve to a regular grid with very simple specification (specify some
> or nothing of target/extent/resolution/crs/dimension). Key problems here
> are when the coordinate arrays are not auto-detected (rare) or when the
> longitudes are unwrapped (less rare).
> - that extent+dimension is complementary to the affine transform, and way
> more user-friendly way to work with rasters for the assign and/or target
> specification step (this is huge in R since the {raster} package ca. 2009
> and very well supported by Warp and Translate). It's true that
> extent+dimension can't do shear params but it's a perfectly valid way to
> work and flipping from transform to extent is trivial numerically.
> I hope some more voices from this community pitch in as well, very happy
> to discuss here or offline about any of this.  I'm not really a technical
> expert but I have a good overview of the landscape that GDAL sits in, and
> I'm making similar pitches for involvement in the R communities.
> Cheers, Mike
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240404/a0cdc253/attachment.htm>
