[gdal-dev] How do I add a projection to proj 8?
Sebastiaan Couwenberg sebastic at xs4all.nl
Fri Apr 12 21:17:45 PDT 2024
On 4/12/24 11:24 PM, Stephen Woodbridge via gdal-dev wrote:
> and was able to access it in gdal, mapserver, postgis, etc with
> "EPSG:900914"
I used to do that too, but switched to EPSG:3857 its non-deprecated
equivalent. I would recommend that instead of trying to keep using a
non-standard projection.
Kind Regards,
Bas
  GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
