[gdal-dev] How do I add a projection to proj 8?
Javier Jimenez Shaw j1 at jimenezshaw.com
Sat Apr 13 03:00:43 PDT 2024
Yes, such CRS was used until EPSG:3857 was added
(900913 tries to mimic Google letters with numbers, as it was used by
google maps).
But the parameters given by Stephen are a bit different. Probably that's
why the number ends with 4
You can see the (deprecated) proj4 string of 900913 at
https://spatialreference.org/ref/epsg/900913/proj4.txt
On Sat, 13 Apr 2024 at 11:12, Sebastiaan Couwenberg via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> On 4/13/24 10:19 AM, Javier Jimenez Shaw via gdal-dev wrote:
> > Bas, are they really equivalent?
> As far as I know they are, where one used to use EPSG:900913 they should
> now be using EPSG:3857, as 900913 is deprecated.
>   https://wiki.openstreetmap.org/wiki/Web_Mercator
> Kind Regards,
> Bas
>   GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240413/95d5854e/attachment.htm>
