[gdal-dev] How do I add a projection to proj 8?
Stephen Woodbridge stephenwoodbridge37 at gmail.com
Sat Apr 13 08:35:56 PDT 2024
Thanks, this is NOT the standard Web Mercator projection. I am aware of
EPSG:90013 and EPSG:3857. This projection is used with HYCOM data that I
have extracted into geotif files so that I can accurately project that
onto EPSG:3857. It took some fiddling with the values to get to overlay
visually correctly. HYCOM data is weird in that it uses two different
projections based on if the data is above or below some latitude.
On 4/13/2024 4:19 AM, Javier Jimenez Shaw via gdal-dev wrote:
> If what you need is really EPSG:3857, yes, use it.
> However I have seen strange parameters on your projection. The radius
> of the sphere is the "average" 3671 km, and you set a false easting
> and northing of just 4.4 km. Is that trying to correct the radius of
> the sphere? I do not know why you need that.
> Bas, are they really equivalent?
> In proj you can convert to WKT1 (see that I added +type=crs):
> projinfo "+proj=merc +a=6371001 +b=6371001 +lat_ts=0.0 +lon_0=0.0
> +x_0=-4448 +y_0=-4448 +k=1.0 +units=m +over +nadgrids=@null +no_defs
>  +type=crs" -o wkt1_gdal
Ok I get this adding by +type=crs but how do I add it to the proj
database so I can access it referencing it by something like EPSG:90014?
Thanks,
   -Steve
> On Sat, 13 Apr 2024 at 06:17, Sebastiaan Couwenberg via gdal-dev
> <gdal-dev at lists.osgeo.org> wrote:
>     On 4/12/24 11:24 PM, Stephen Woodbridge via gdal-dev wrote:
>     > and was able to access it in gdal, mapserver, postgis, etc with
>     > "EPSG:900914"
>     I used to do that too, but switched to EPSG:3857 its non-deprecated
>     equivalent. I would recommend that instead of trying to keep using a
>     non-standard projection.
>     Kind Regards,
>     Bas
>       GPG Key ID: 4096R/6750F10AE88D4AF1
>     Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
>     _______________________________________________
>     gdal-dev mailing list
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
This email has been checked for viruses by Avast antivirus software.
www.avast.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240413/ed315545/attachment-0001.htm>
