[gdal-dev] Potential geopackage rtree problem on MacOS ARM64
Even Rouault even.rouault at spatialys.com
Tue Apr 16 12:01:01 PDT 2024
I've investigated that today, and I can quite reliably trigger a similar
error with our existing tests on CI, but this is impossible to diagnose
further without direct access to a machine where the error triggers
(when simulating taking the the error code path on Linux, the fallback
code works, whereas it doesn't on OSX Arm64, so there's something quite
subtle happening here). So if someone has a OSX Arm64 and is willing to
give me ssh access to it, that would be welcome.
In the meantime, I've submitted https://github.com/OSGeo/gdal/pull/9685
which is just a workaround to disable (by default) the threaded RTree
creation on that platform. It can be explicitly enabled by setting
OGR_GPKG_ALLOW_THREADED_RTREE to YES
Even
Le 16/04/2024 à 08:13, Rahkonen Jukka via gdal-dev a écrit :
> Hi,
> It seems that at least two MacOS ARM64 users have faced a problem with
> the new, faster rtree creation method so maybe it is worth having a
> look. Obviously a big dataset and right hardware is needed for testing
> https://gis.stackexchange.com/questions/479958/how-to-fix-failed-to-prepare-sql-error-when-creating-gpkg-file-from-osm-extrac/479964#479964
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240416/6e94d46c/attachment.htm>
