[gdal-dev] Potential geopackage rtree problem on MacOS ARM64
Even Rouault even.rouault at spatialys.com
Thu Apr 18 16:31:27 PDT 2024
ok, I believe I've now a fix in https://github.com/OSGeo/gdal/pull/9700
. Probably a subtle multi-threading issue related to different memory
ordering between M1 and Intel CPUs (or just that it was easier to
trigger on M1)
Le 16/04/2024 à 21:01, Even Rouault via gdal-dev a écrit :
> Hi,
> I've investigated that today, and I can quite reliably trigger a
> similar error with our existing tests on CI, but this is impossible to
> diagnose further without direct access to a machine where the error
> triggers (when simulating taking the the error code path on Linux, the
> fallback code works, whereas it doesn't on OSX Arm64, so there's
> something quite subtle happening here). So if someone has a OSX Arm64
> and is willing to give me ssh access to it, that would be welcome.
> In the meantime, I've submitted
> https://github.com/OSGeo/gdal/pull/9685 which is just a workaround to
> disable (by default) the threaded RTree creation on that platform. It
> can be explicitly enabled by setting OGR_GPKG_ALLOW_THREADED_RTREE to YES
> Even
> Le 16/04/2024 à 08:13, Rahkonen Jukka via gdal-dev a écrit :
>> Hi,
>> It seems that at least two MacOS ARM64 users have faced a problem
>> with the new, faster rtree creation method so maybe it is worth
>> having a look. Obviously a big dataset and right hardware is needed
>> for testing
>> https://gis.stackexchange.com/questions/479958/how-to-fix-failed-to-prepare-sql-error-when-creating-gpkg-file-from-osm-extrac/479964#479964
>> -Jukka Rahkonen-
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240419/b4407a74/attachment.htm>
