[gdal-dev] gdalwarp with RPCs causing bogus output
Joseph McGlinchy jmcglinchy at hydrosat.com
Wed Apr 17 14:30:25 PDT 2024
Hello,
I am attempting to implement georegistration through RPC. I have the following information I've used to calibrate the RPC coefficients, using all terms for numerator and denominator for both sample and line equations.
image grid, stored in tiff format with no geo-information associated with it, so it reflects the imaging orientation
a 'ground' grid, which corresponds to the longitude/latitude coordinates for each pixel determined from a line-of-sight vector and imaging system coordinates where the pseudo-rays intersect the WGS84 geoid
a random sample of up to 4000 image coordinate / object space coordinate pairs (I arrived at this number through trial and error; using all pixels explodes RAM)
elevation extracted at the longitude/latitude coordinates from a DEM, in this case, SRTM, but have also tried using NASADEM
I am able to write out an image to EPSG:4326 by populating the RPC metadata and using the non-georeferenced image data. However, I am struggling to use gdalwarp​ in a reliable way to orthorectify that data, let alone writing it out in a way that 'bakes in' the georegistration with the RPCs whether that is in EPSG:4326 or the local UTM zone. I see strips of the image "ripped out" with odd curves in various places throughout the image.
The only way I've been able to use gdalwarp​ to write the image at all is with the following parameters (any DEM reference is to the SRTM DEM):
gdalwarp --config CPL_DEBUG ON -t_srs EPSG:32610 -rpc -to "RPC_DEM_SRS=+proj=longlat +datum=WGS84 +no_def" -to "RPC_HEIGHT=350" -to "RPC_DEM_MISSING_VALUE=0.001" -to "RPC_FOOTPRINT='POLYGON ((list of polygon coordinates comprising the long/lat grid))'" -to "RPC_MAX_ITERATIONS=101" input_with_RPCs.tiff output.tiff
This is the only configuration i can use to run gdalwarp​ successfully.  removing any single RPC_X tranformer option gives me bogus output. The RPC_HEIGHT value i specify above is not close to the mean or median elevation of the extent of my data; mean is ~195m and median is ~150m.
With the debug turned on, any other set of parameters gives me failed RPC convergence on several points. I am able to reproduce this regularly by specifying RPC_DEM=dem.tif, where dem.tif is the same data I used to extract elevation values when calibrating the RPCs. I am seeing normalized latitude and longitude values with magnitude > 1 (I checked every location in the image, based on the metadata, the range is not outside of [-1,1]), as well as normalized altitude values with magnitude > 1 (there are some, not many, that have magnitude of 1.75).
My workflow can be summarized as:
  1.
load grids (image data, longitude, latitude)
  2.
randomly sample up to 4000 points in image coordinates, object coordinates
assign z-value from SRTM DEM
evaluate if any of the points are in NODATA areas of SRTM (image is coastal, so there are NODATA areas for SRTM here), if so, remove those and generate more points
  3.
normalize coordinates of grids to be in [-1,1], recording offsets and scale
  4.
 calibrate RPC coefficients using all terms
  5.
write out GeoTIFF with image grid for pixels, along with RPC required metadata fields and CRS EPSG:4326
System information (please let me know if more is needed)
OS: Ubuntu 20.04 LTS (GNU/Linux 5.10.16.3-microsoft-standard-WSL2 x86_64) (Windows Subsystem for Linux)
GDAL 3.6.0 (python)
Thank you in advance for any insight into this process! I am happy to package up any of the data I am using, as well. I have placed the initial data from the end of Step 5 described above, along with some additional files, a sample gdalwarp call, and a file-list.txt, at https://drive.google.com/drive/folders/1BfevhKQa4ZHi_OQfiX_rUk2sqeoNVhyM?usp=sharing
If more is needed for anyone interested in having a look, please let me know and I'll upload.
Cheers,
Joe
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240417/c3fea5d2/attachment-0001.htm>
