[gdal-dev] Hungarian Notation
Kurt Schwehr schwehr at gmail.com
Wed Apr 17 09:49:10 PDT 2024
My personal take:
I slightly Hungarian notation and it seems to me like needing that extra
notation points to other coding style issues. However, I think moving away
from it would be a chaotic mess for GDAL. It would be a massive change to
switch it all. Consistency is critical.
On Wed, Apr 17, 2024 at 9:10 AM Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> This is described in https://gdal.org/development/rfc/rfc8_devguide.html
> . I've submitted https://github.com/OSGeo/gdal/pull/9689 so it is going
> to be linked to
> https://gdal.org/development/dev_practices.html#making-changes-to-gdal
> I'd probably agree that at my beginnings in GDAL, I might have felt
> unfamiliar with the Hungarian notation, but now I've fully internalized it,
> so I hardly notice it. It would be interesting to have opinions of other
> developers if they find it inconvenient/a hurdle, are neutral or like it.
> The thing is that if we decide to no longer use it, the inconsistency of
> mixing free style naming and Hungarian notation might be problematic and
> make code confusing. We should probably aim at being consistent at least at
> the scope of a given function or file.
> Even
> Le 17/04/2024 à 15:48, Andrew Bell via gdal-dev a écrit :
> Hi,
> I was going to make some changes to some GDAL code and I generally want to
> follow along. I see that most of the code is still using Hungarian notation
> for identifier names. I haven't seen this anywhere else in like 20 years.
> Is it OK to submit code without this naming convention or do we still
> think it's important. I didn't see an RFC or documentation that covers
> this, but there's lots so I may have missed it.
> Thanks,
> Andrew Bell
> andrew.bell.ia at gmail.com
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240417/a5516cbf/attachment-0001.htm>
