[gdal-dev] Export PG to GPKG with foreign keys
Even Rouault even.rouault at spatialys.com
Fri Apr 19 02:32:29 PDT 2024
Le 19/04/2024 à 10:25, Matteo Ghetta via gdal-dev a écrit :
> Hi all,
> I'm trying to export a PG table with several foreign keys to a
> geopackage.
> What I tried so far are the native QGIS export and the QGIS Processing
> algorithm "Package layer" with the "Export related layers
> following..." option activated.
> I'm checking ogr2ogr but I cannot see any option to include the export
> of the foreign keys. Is this option available in order to have a
> geopackage with the original table with all the other related tables?
In short, no
It might be possible to use the relationship API of
https://gdal.org/api/gdaldataset_cpp.html#_CPPv4NK11GDALDataset20GetRelationshipNamesE12CSLConstList
to build something around it. But adding foreign key constraint
themselves would be tricky as it requires to rewrite the CREATE TABLE.
Even
http://www.spatialys.com
