[gdal-dev] Block cache and VRT sources
Sean Gillies sean.gillies at gmail.com
Fri Apr 19 07:48:45 PDT 2024
Happy Friday, folks!
Are the source rasters of a VRT added to the block cache such that
different VRTs using the same source can avoid reads from disk or the
network? Or is it intended that the VSI cache covers this need instead?
Thanks,
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240419/96ecf10a/attachment.htm>
