[gdal-dev] GDAL 3.9.0beta1 available for testing
Even Rouault even.rouault at spatialys.com
Mon Apr 22 06:25:56 PDT 2024
Robert,
If you want to use ready-made binaries, then using Conda gdal-master
builds might be the easiest way for all major platforms:
https://gdal.org/download.html#gdal-master-conda-builds . They track
gdal master, but that's more or less the same as 3.9.0beta1 right now.
Otherwise if you want to build from source, you can take inspiration
from the build recipe we use for continuous integration:
https://github.com/OSGeo/gdal/blob/master/.github/workflows/ubuntu_22.04/Dockerfile.ci
https://github.com/OSGeo/gdal/blob/master/.github/workflows/ubuntu_22.04/build.sh
(you don't necessarily need all the dependencies)
And as I mentioned, Docker images are building. Should be ready by tomorrow.
Even
Le 22/04/2024 à 15:18, Robert Hewlett via gdal-dev a écrit :
> Any advice on how to become a tester such as testing on prefered OS
> and setup?
> I have access to a proxmox server but I usually stick to LINUX OSes.
> Or is at easy as following the notes here:
> https://gdal.org/development/dev_environment.html
> Ubuntu 22.x is the goto right now.
> Any advice would be appreciated.
> Rob
> On Mon, Apr 22, 2024 at 5:12 AM Even Rouault via gdal-dev
> <gdal-dev at lists.osgeo.org> wrote:
>     Hi,
>     I've prepared a beta1 of GDAL 3.9.0 to get feedback from early
>     testers.
>     The NEWS file is here:
>     https://github.com/OSGeo/gdal/blob/v3.9.0beta1/NEWS.md
>     For packagers,
>     https://gdal.org/development/rfc/rfc96_deferred_plugin_loading.html
>     may
>     make it more attractive to build some drivers that typically have
>     heavy
>     dependencies as plugins, installable in separate packages, due to the
>     load time penalty having being improved. It is let to the
>     appreciation
>     of packagers to decide which drivers are worth building as plugins
>     installable in a separate package.
>     You may also pass CMake options
>     ([GDAL/OGR]_DRIVER_<driver_name>_PLUGIN_INSTALLATION_MESSAGE=xxx) so
>     user get a hint of which package they need to install when GDAL
>     detects
>     that a file may be opened by a plugin which is not available on
>     the file
>     system but known to have been built as a plugin. Cf
>     https://gdal.org/development/building_from_source.html#deferred-loaded-plugins
>     for more details.
>     For end-users, the following utilities have been updated to use a new
>     argument parsing framework: gdaladdo, gdalinfo, gdal_translate,
>     gdalwarp, gdal_grid, gdal_viewshed, gdalbuildvrt, nearblack, ogrinfo,
>     ogr2ogr, sozip.
>     This helps detecting errors such as specifying twice an argument that
>     should be specified once (where generally the last instance was
>     the one
>     used). While we have tried to retain backwards compatibility for
>     nominal
>     use cases, obviously if you have scripts that accidentally specify an
>     argument several times whereas it should be specified at most
>     once, they
>     will have to be corrected.
>     Docker images with 3.9.0beta1 are currently cooking.
>     master is now marked as 3.10.0dev, and the release/3.9 branch has
>     been
>     created. All bugfixes for 3.9 should be backported into it.
>     Source snapshots at:
>     - https://download.osgeo.org/gdal/3.9.0/gdal-3.9.0beta1.tar.gz
>     - https://download.osgeo.org/gdal/3.9.0/gdal-3.9.0beta1.tar.xz
>     - https://download.osgeo.org/gdal/3.9.0/gdal380beta1.zip
>     Autotest snapshots:
>     - https://download.osgeo.org/gdal/3.9.0/gdalautotest-3.9.0beta1.tar.gz
>     - https://download.osgeo.org/gdal/3.9.0/gdalautotest-3.9.0beta1.zip
>     Even
>     http://www.spatialys.com
>     My software is free, but my time generally not.
>     _______________________________________________
>     gdal-dev mailing list
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240422/067c0e0a/attachment.htm>
