[gdal-dev] GDAL 3.9.0beta1 available for testing
    Sean Gillies
    sean.gillies at gmail.com
    Mon Apr 22 09:14:55 PDT 2024
Hi Even,
Rasterio's test suite has 4 errors with GDAL 3.9.0beta1.
Metadata output of gdalinfo has changed. As soon as there are docker images
I'll look more closely at this.
Writing a mask to a Rasterio RGB.byte.tif dataset no longer creates a
RGB.byte.tif.msk
file:
https://github.com/rasterio/rasterio/actions/runs/8786444142/job/24109342188#step:8:2231
The text of an error message which was "tests/data/corrupt.tif, band 1:
IReadBlock failed at X offset 1, Y offset 1: TIFFReadEncodedTile() failed."
in 3.8 has changed to "corrupt.tif, band 1: IReadBlock failed at X offset
1, Y offset 1: TIFFReadEncodedTile() failed." This is not a big deal, we
can adjust Rasterio's test.
Behavior of SRC_METHOD/DST_METHOD=NO_GEOTRANSFORM for warp options seems to
have changed:
https://github.com/rasterio/rasterio/actions/runs/8786444142/job/24109342188#step:8:2287.
I'm not entirely sure what the intent is in Rasterio's test, will dig into
that. I just wanted to say that I see a change in GDAL.
On Mon, Apr 22, 2024 at 6:12 AM Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> I've prepared a beta1 of GDAL 3.9.0 to get feedback from early testers.
> The NEWS file is here:
>    https://github.com/OSGeo/gdal/blob/v3.9.0beta1/NEWS.md
> For packagers,
> https://gdal.org/development/rfc/rfc96_deferred_plugin_loading.html may
> make it more attractive to build some drivers that typically have heavy
> dependencies as plugins, installable in separate packages, due to the
> load time penalty having being improved. It is let to the appreciation
> of packagers to decide which drivers are worth building as plugins
> installable in a separate package.
> You may also pass CMake options
> ([GDAL/OGR]_DRIVER_<driver_name>_PLUGIN_INSTALLATION_MESSAGE=xxx) so
> user get a hint of which package they need to install when GDAL detects
> that a file may be opened by a plugin which is not available on the file
> system but known to have been built as a plugin. Cf
> https://gdal.org/development/building_from_source.html#deferred-loaded-plugins
> for more details.
> For end-users, the following utilities have been updated to use a new
> argument parsing framework: gdaladdo, gdalinfo, gdal_translate,
> gdalwarp, gdal_grid, gdal_viewshed, gdalbuildvrt, nearblack, ogrinfo,
> ogr2ogr, sozip.
> This helps detecting errors such as specifying twice an argument that
> should be specified once (where generally the last instance was the one
> used). While we have tried to retain backwards compatibility for nominal
> use cases, obviously if you have scripts that accidentally specify an
> argument several times whereas it should be specified at most once, they
> will have to be corrected.
> Docker images with 3.9.0beta1 are currently cooking.
> master is now marked as 3.10.0dev, and the release/3.9 branch has been
> created. All bugfixes for 3.9 should be backported into it.
> Source snapshots at:
> - https://download.osgeo.org/gdal/3.9.0/gdal-3.9.0beta1.tar.gz
> - https://download.osgeo.org/gdal/3.9.0/gdal-3.9.0beta1.tar.xz
> - https://download.osgeo.org/gdal/3.9.0/gdal380beta1.zip
> Autotest snapshots:
> - https://download.osgeo.org/gdal/3.9.0/gdalautotest-3.9.0beta1.tar.gz
> - https://download.osgeo.org/gdal/3.9.0/gdalautotest-3.9.0beta1.zip
> Even
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240422/84716b2f/attachment.htm>
