[gdal-dev] GDAL 3.9.0beta1 available for testing
Even Rouault even.rouault at spatialys.com
Mon Apr 22 14:52:06 PDT 2024
Holger,
thanks for the report. This should be fixed per
https://github.com/OSGeo/gdal/commit/fba559b5bd8d33aac215681df4f6a613517a6c43
which I've backported to the release/3.9 branch
A workaround is to explicitly run "cmake --target
generate_gdal_version_h" before building all other targets
Even
Le 22/04/2024 à 23:28, Holger Jaekel via gdal-dev a écrit :
> Hi Even,
> Am 22.04.24 um 14:12 schrieb Even Rouault via gdal-dev:
>> I've prepared a beta1 of GDAL 3.9.0 to get feedback from early testers.
> I tried to build on Alpine Linux Edge and got the following error:
> /builds/hjaekel/aports/community/gdal/src/gdal-3.9.0beta1/ogr/ogr_core.h:38:10:
> fatal error: gdal_version.h: No such file or directory
>    38 | #include "gdal_version.h"
> compilation terminated.
> gdal_version.h seems not to be generated to build/gcore.
> You can find the full build logs here:
> https://gitlab.alpinelinux.org/hjaekel/aports/-/pipelines/228841
> Holger
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
