[gdal-dev] GDAL 3.9.0beta1 available for testing
Holger Jaekel holger.jaekel at gmx.de
Tue Apr 23 09:58:56 PDT 2024
Even,
Thanks for the quick fix, I can confirm that it works.
Holger
Am 22.04.24 um 23:52 schrieb Even Rouault:
> Holger,
> thanks for the report. This should be fixed per
> https://github.com/OSGeo/gdal/commit/fba559b5bd8d33aac215681df4f6a613517a6c43 which I've backported to the release/3.9 branch
> A workaround is to explicitly run "cmake --target
> generate_gdal_version_h" before building all other targets
> Even
> Le 22/04/2024 à 23:28, Holger Jaekel via gdal-dev a écrit :
>> Hi Even,
>> Am 22.04.24 um 14:12 schrieb Even Rouault via gdal-dev:
>>> I've prepared a beta1 of GDAL 3.9.0 to get feedback from early testers.
>> I tried to build on Alpine Linux Edge and got the following error:
>> /builds/hjaekel/aports/community/gdal/src/gdal-3.9.0beta1/ogr/ogr_core.h:38:10:
>> fatal error: gdal_version.h: No such file or directory
>>    38 | #include "gdal_version.h"
>> compilation terminated.
>> gdal_version.h seems not to be generated to build/gcore.
>> You can find the full build logs here:
>> https://gitlab.alpinelinux.org/hjaekel/aports/-/pipelines/228841
>> Holger
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
