[gdal-dev] GDAL 3.9.0beta1 available for testing
Even Rouault even.rouault at spatialys.com
Mon Apr 22 14:56:45 PDT 2024
The Docker images are now available:
ghcr.io/osgeo/gdal:alpine-small-3.9.0beta1
ghcr.io/osgeo/gdal:ubuntu-small-3.9.0beta1
ghcr.io/osgeo/gdal:alpine-normal-3.9.0beta1
ghcr.io/osgeo/gdal:ubuntu-full-3.9.0beta1
Le 22/04/2024 à 14:12, Even Rouault via gdal-dev a écrit :
> Hi,
> I've prepared a beta1 of GDAL 3.9.0 to get feedback from early testers.
> The NEWS file is here:
>   https://github.com/OSGeo/gdal/blob/v3.9.0beta1/NEWS.md
> For packagers,
> https://gdal.org/development/rfc/rfc96_deferred_plugin_loading.html
> may make it more attractive to build some drivers that typically have
> heavy dependencies as plugins, installable in separate packages, due
> to the load time penalty having being improved. It is let to the
> appreciation of packagers to decide which drivers are worth building
> as plugins installable in a separate package.
> You may also pass CMake options
> ([GDAL/OGR]_DRIVER_<driver_name>_PLUGIN_INSTALLATION_MESSAGE=xxx) so
> user get a hint of which package they need to install when GDAL
> detects that a file may be opened by a plugin which is not available
> on the file system but known to have been built as a plugin. Cf
> https://gdal.org/development/building_from_source.html#deferred-loaded-plugins
> for more details.
> For end-users, the following utilities have been updated to use a new
> argument parsing framework: gdaladdo, gdalinfo, gdal_translate,
> gdalwarp, gdal_grid, gdal_viewshed, gdalbuildvrt, nearblack, ogrinfo,
> ogr2ogr, sozip.
> This helps detecting errors such as specifying twice an argument that
> should be specified once (where generally the last instance was the
> one used). While we have tried to retain backwards compatibility for
> nominal use cases, obviously if you have scripts that accidentally
> specify an argument several times whereas it should be specified at
> most once, they will have to be corrected.
> Docker images with 3.9.0beta1 are currently cooking.
> master is now marked as 3.10.0dev, and the release/3.9 branch has been
> created. All bugfixes for 3.9 should be backported into it.
> Source snapshots at:
> - https://download.osgeo.org/gdal/3.9.0/gdal-3.9.0beta1.tar.gz
> - https://download.osgeo.org/gdal/3.9.0/gdal-3.9.0beta1.tar.xz
> - https://download.osgeo.org/gdal/3.9.0/gdal380beta1.zip
> Autotest snapshots:
> - https://download.osgeo.org/gdal/3.9.0/gdalautotest-3.9.0beta1.tar.gz
> - https://download.osgeo.org/gdal/3.9.0/gdalautotest-3.9.0beta1.zip
> Even
http://www.spatialys.com
