[gdal-dev] GDAL 3.9.0beta2 available for testing
Even Rouault even.rouault at spatialys.com
Mon Apr 29 05:26:48 PDT 2024
I've prepared a beta2 of GDAL 3.9.0 as there have been a few non-trivial
changes since beta1
The major ones are:
* pyproject.toml: use numpy>=2.0.0rc1 for python >=3.9 (#9751)
* Docker: update ubuntu-small and ubuntu-full to 24.04
* TileDB: migrate away from deprecated APIs, and bump minimum version to
2.15
Other bugfixes:
* CMake: add missing dependency to generate_gdal_version_h target when
building {plugin}_core targets
* CMake: fix generated find_dependency
* Miramon: various fixes
* GDALSuggestedWarpOutput2(): make changes of PR #9336 honour
SRC_METHOD=NO_GEOTRANSFORM. Fixes failure on rasterio
tests/test_warpedvrt.py::test_transformer_options__width_height
* Update p-ranav/argparse to latest master; ogrinfo and ogr2ogr: update
to use store_into(GIntBig&)
* GDALOpen(): avoid double '.' in error messages related to plugin drivers
* Add OSRIsDerivedProjected() / OGRSpatialReference::IsDerivedProjected()
* OGR_CT: use PROJJSON internally rather than in WKT:2019 (#9732)
* GDALArgumentParser: fix dealing with positional arguments that are
negative numeric values
* GDALVectorInfo(): fix 3.9.0beta1 regression regarding passing layer names
* Internal libtiff: updated to latest upstream
* gdalinfo and ogrinfo -json: add newline character at end of JSON
output (qgis#57266)
* OGRFeature::SetField(): add warnings when detecting some lossy
conversions (refs #9792)
* Arrow/Parquet: fix writing empty point Z with
GEOMETRY_ENCODING=GEOARROW_INTERLEAVED, and test spatial filtering of
that encoding (qgis#57228)
* OGRLayer::WriteArrowBatch(): add tolerance for field type mismatches
if int32/int64/real; Also add an option IF_FIELD_NOT_PRESERVED=ERROR to
error out when lossy conversion occurs. (#9792)
* Parquet: fix ResetReading() implementation, when using the
ParquetDataset API and when there's a single batch
* Parquet: fix opening single file Parquet datasets with the
ParquetDataset API when using PARQUET:filename.parquet
* OGRCloneArrowArray(): add missing support for 'tss:' Arrow type
Docker images with 3.9.0beta2 are currently cooking.
Source snapshots at:
- https://download.osgeo.org/gdal/3.9.0/gdal-3.9.0beta2.tar.gz
- https://download.osgeo.org/gdal/3.9.0/gdal-3.9.0beta2.tar.xz
- https://download.osgeo.org/gdal/3.9.0/gdal390beta2.zip
Autotest snapshots:
- https://download.osgeo.org/gdal/3.9.0/gdalautotest-3.9.0beta2.tar.gz
- https://download.osgeo.org/gdal/3.9.0/gdalautotest-3.9.0beta2.zip
Even
http://www.spatialys.com
