[gdal-dev] Reading DXF block attributes
Simon Gröchenig groechenig at zt-gis.at
Mon Apr 29 05:43:38 PDT 2024
Hi all,
I attempt to copy DXF data to GPKG using the following command:
ogr2ogr --config DXF_MERGE_BLOCK_GEOMETRIES FALSE --config DXF_INLINE_BLOCKS FALSE -f "GPKG" D:/tmp/632_20-2N.gpkg D:/tmp/632_20-2N.dxf --debug ON
My DXF contains some blocks with several block attributes. According to https://gdal.org/drivers/vector/dxf.html, the attributes should be written to the BlockAttributes field if DXF_INLINE_BLOCKS is set to false. However, this field remains empty ("") in my case.
Can you confirm that ogr2ogr can read DXF block attributes? (according to the known issues at Github, writing block attributes is not yet supported)
Any ideas why the field BlockAttributes (also BlockScale, BlockOCSNormal, BlockOCSCoords) is set to "" in the GPKG? BlockName and BlockAngle are set correctly.
Best regards
Simon
_______________________________
Vermessungskanzlei Neumayr
Simon Gröchenig - Geoinformation
Albin Egger-Str. 10
9900 Lienz
Tel: +43 4852 68568 31
Mobil: +43 664 1544804
Email: groechenig at zt-gis.at<mailto:groechenig at zt-gis.at>
Web: http://www.zt-gis.at/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240429/9225c7a5/attachment-0001.htm>
