[gdal-dev] Reading interpolated values on DSM
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Apr 29 09:01:12 PDT 2024
Hi all
Thanks for your answers
Just to get some values, the VRT was enough to get an idea. Thanks Jukka.
The questions was more like "this should be somewhere, and I do not find
it", but apparently "it was not there".
I see that GDALRasterInterpolateAtPoint could be useful (I am surprised it
was was not needed before). I will try to add it at some point.
Best regards,
Javier.
On Wed, 24 Apr 2024 at 15:16, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le 24/04/2024 à 15:00, Michael Sumner a écrit :
> Or a grouping function that returned the cell index for neighbours and
> weighting that are involved in whatever calculation summary is wanted.
> That doesn't seem super user friendly, as users would still be left to do
> the raster value extraction and applying the weights, taking into account
> nodata, etc. Not trivial. What is the advantage of this compared to
> returning the interpolated value? The only one I see is to potentially save
> a bit of computation if you need to interpolate values at the same location
> in multiple bands, but the performance gain would probably be marginal (or
> if not, then a variant of the function dealing with multiple bands could be
> offered)
> Maybe the warper could return this as a starting point rather than doing
> the "task at hand". ?
> The warper code has indeed a "FilterFuncType
> GWKGetFilterFunc(GDALResampleAlg eResampleAlg)" method that returns a
> function that returns interpolation weights and int
> GWKGetFilterRadius(GDALResampleAlg eResampleAlg). The code in
> GDALRPCGetDEMHeight() has an interesting logic where it caches a window of
> interest around the first queried pixel so that subsequent queries in the
> neighbouroud can be honoured without going to RasterIO(). This
> substantially improves performance in the RPC case, in particular during
> reverse transformation where you use an iterative method and thus may need
> a lot of DEM extraction to compute a single point.
> On Wed, Apr 24, 2024 at 8:51 PM Even Rouault via gdal-dev <
> gdal-dev at lists.osgeo.org> wrote:
>> Hi,
>> I guess this discussion, and past similar ones, calls for an enhancement.
>> A new API function, like CPLErr
>> GDALRasterInterpolateAtPoint(GDALRasterBandH, double dfPixel, double
>> dfLocation, GDALRIOResampleAlg eInterpolation, double *pdfValue), that
>> could be used by a new mode of gdallocationinfo. The GDALRPCGetDEMHeight()
>> function in alg/gdal_rpc.cpp is a plausible candidate implementation for
>> bilinear and bicubic (we could potentially restrict to that at the moment).
>> Even
>> Le 24/04/2024 à 10:33, Javier Jimenez Shaw via gdal-dev a écrit :
>> Hi
>> I would like to read in QGIS or GDAL an interpolated value in a DSM
>> (well, actually it is a geoid model, but it is the same behaviour). See
>> that I do not want the pixel value, but the linear interpolation among the
>> neighbour pixels, assuming that the pixel value is in the center of the
>> pixel.
>> For instance, this file
>> https://www.isgeoid.polimi.it/Geoid/Asia/Japan/japan2000_g.html
>> Is there any way to get it (without implementing the interpolation
>> myself)?
>> If I understood correctly gdallocationinfo is not interpolating, just
>> giving the pixel value.
>> Thanks
>> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240429/3ce9e311/attachment.htm>
