[gdal-dev] Re-post, user-defined
Even Rouault even.rouault at spatialys.com
Mon Apr 29 15:11:44 PDT 2024
At first sight, I'd say that the ArcPy output is incorrect. The SRS
definition of its output doesn't match what you want since it has
PARAMETER["Latitude of natural origin",20,
ANGLEUNIT["degree",0.0174532925199433],
ID["EPSG",8801]],
PARAMETER["Longitude of natural origin",6378137,
ID["EPSG",8802]],
PARAMETER["False easting",5,
LENGTHUNIT["metre",1],
ID["EPSG",8806]],
The "Longitude of natural origin" is completely wrong, and should be 5
given the PROJ.4 string you mentionned
And the the "False easting" should be 0.
The output of GDAL looks plausible.
Le 30/04/2024 à 00:00, Liyuneh Gebre a écrit :
> Hi Even,
> thank you for your response,
> gdal version is: GDAL 3.6.4, released 2023/04/17
> I got the defined target projection included in the link. yes, it's
> geocentric and for further exploration the custom project
> transformation file .gtf extension is also included.
> https://u.pcloud.link/publink/show?code=kZj5wh0ZtFWXtI9UGjQiD6KXxn5A9hiWDpEX
> On Mon, Apr 29, 2024 at 4:23 PM Even Rouault
> <even.rouault at spatialys.com> wrote:
>     Hi,
>     it is difficult to help you with just the elements you've provided.
>     What could be helpful is:
>     - the output of gdalinfo on the input file
>     - the output of gdalinfo on the output file generate by ArcPy
>     - how you define the target projection in ArcPy
>     - the output of gdalinfo on the output file generate by GDAL
>     - links to all the above files
>     - the GDAL version you use
>     Totally blind guess: try to add "+towgs84=0,0,0 " in your -t_srs
>     PROJ string, to ask PROJ to consider that your target CRS datum
>     has the same center and axis orientation as WGS84 (and thus go to
>     geographic <--> geocentric conversion when changing datums).
>     Otherwise without datum shifts, PROJ will consider that
>     longitude,latitude coordinates of the geographic CRS underlying
>     the source and target CRS is the same.
>     Even
>     Le 29/04/2024 à 14:57, Liyuneh Gebre via gdal-dev a écrit :
>>     Dear all,
>>     I am requesting again if you kind have some responds or
>>     direction, thank you
>>     I have difficulties in accurately reprojecting a raster file to a
>>     user-defined projection.
>>     I used the following commands in gdal while the output is not
>>     similar to arcpy results.  kindly offer your guidance to achieve
>>     the same result.  The arcpy uses custom transformation and then
>>     reprojection.
>>     gdalwarp -t_srs '+proj=laea +a=6378137.0 +f=0.0 +pm=0 +x_0=0.0
>>     +y_0=0.0 +lon_0=20.0 +lat_0=5.0 +units=m +axis=enu +no_defs'
>>     -dstalpha -wo SOURCE_EXTRA=1000 -r nearest rain_in.bil
>>     rain_projected.bil
>>     /*Liyuneh Gebre*//, ////Associate Researcher///
>>     /Ethiopian Institute of Agricultural Research,EIAR
>>     /Cell Phone:+251 911858155
>>     /linkedIn: https://www.linkedin.com/in/liyuneh-gebre-b842b440/
>>     //skype:liyenew_1//
>>     /Addis Ababa, Ethioipa/
>>     _______________________________________________
>>     gdal-dev mailing list
>>     gdal-dev at lists.osgeo.org
>>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
>     http://www.spatialys.com
>     My software is free, but my time generally not.
> //skype:liyenew_1//
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240430/022e06ac/attachment-0001.htm>
