[gdal-dev] Re-post, user-defined
Liyuneh Gebre liyenew at gmail.com
Mon Apr 29 16:55:50 PDT 2024
Well the arcpy made transformation before re-projection. Appended the
sample script in the shared folder as txt. Anyway how can I achieve this
ArcPy output re-projection from gdal with the given gdalinfo on the input
file  and by editing the PROJ.4 string (target projection )?
PARAMETER["Latitude of natural origin",20,
ANGLEUNIT["degree",0.0174532925199433],
ID["EPSG",8801]],
PARAMETER["Longitude of natural origin",6378137,
ID["EPSG",8802]],
PARAMETER["False easting",5,
LENGTHUNIT["metre",1],
ID["EPSG",8806]],
On Tue, Apr 30, 2024 at 1:11 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> At first sight, I'd say that the ArcPy output is incorrect. The SRS
> definition of its output doesn't match what you want since it has
> ID["EPSG",8801]],
> ID["EPSG",8802]],
> ID["EPSG",8806]],
> The "Longitude of natural origin" is completely wrong, and should be 5
> given the PROJ.4 string you mentionned
> And the the "False easting" should be 0.
> The output of GDAL looks plausible.
> Le 30/04/2024 à 00:00, Liyuneh Gebre a écrit :
> Hi Even,
> thank you for your response,
> gdal version is: GDAL 3.6.4, released 2023/04/17
> I got the defined target projection included in the link. yes, it's
> geocentric and for further exploration the custom project transformation
> file .gtf extension is also included.
> https://u.pcloud.link/publink/show?code=kZj5wh0ZtFWXtI9UGjQiD6KXxn5A9hiWDpEX
> On Mon, Apr 29, 2024 at 4:23 PM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Hi,
>> it is difficult to help you with just the elements you've provided.
>> What could be helpful is:
>> - the output of gdalinfo on the input file
>> - the output of gdalinfo on the output file generate by ArcPy
>> - how you define the target projection in ArcPy
>> - the output of gdalinfo on the output file generate by GDAL
>> - links to all the above files
>> - the GDAL version you use
>> Totally blind guess: try to add "+towgs84=0,0,0 " in your -t_srs PROJ
>> string, to ask PROJ to consider that your target CRS datum has the same
>> center and axis orientation as WGS84 (and thus go to geographic <-->
>> geocentric conversion when changing datums). Otherwise without datum
>> shifts, PROJ will consider that longitude,latitude coordinates of the
>> geographic CRS underlying the source and target CRS is the same.
>> Even
>> Le 29/04/2024 à 14:57, Liyuneh Gebre via gdal-dev a écrit :
>> Dear all,
>> I am requesting again if you kind have some responds or direction, thank
>> you
>> I have difficulties in accurately reprojecting a raster file to a
>> user-defined projection.
>> I used the following commands in gdal while the output is not similar to
>> arcpy results.  kindly offer your guidance to achieve the same result.  The
>> arcpy uses custom transformation and then reprojection.
>> gdalwarp -t_srs '+proj=laea +a=6378137.0 +f=0.0 +pm=0 +x_0=0.0 +y_0=0.0
>> +lon_0=20.0 +lat_0=5.0 +units=m +axis=enu +no_defs'  -dstalpha  -wo
>> SOURCE_EXTRA=1000 -r nearest rain_in.bil rain_projected.bil
>> *Liyuneh Gebre**, **Associate Researcher*
>> *Ethiopian Institute of Agricultural Research,EIAR *
>> *Cell Phone:+251 911858155 *
>> *linkedIn: https://www.linkedin.com/in/liyuneh-gebre-b842b440/
>> <https://www.linkedin.com/in/liyuneh-gebre-b842b440/> *
>> *skype:liyenew_1*
>> *Addis Ababa, Ethioipa*
>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
> *skype:liyenew_1*
*Ethiopian Institute of Agricultural Research,EIAR*
*Cell Phone:+251 911858155*
<https://www.linkedin.com/in/liyuneh-gebre-b842b440/>*
*skype:liyenew_1*
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240430/ec6aeba7/attachment.htm>
