[gdal-dev] another problem HDF5
Michael Sumner mdsumner at gmail.com
Tue Apr 30 00:45:12 PDT 2024
This time, with:
https://n5eil01u.ecs.nsidc.org/ATLAS/ATL20.004/2018.10.14/ATL20-01_20181001010615_00370101_004_01.h5
NETCDF gets the geotransform (from x_grid,y_grid which report in the
metadata) but no crs:
  gdalinfo NETCDF:ATL20-02_20181001010615_00370101_004_01.h5 -sd 1 -nomd
Driver: netCDF/Network Common Data Format
Files: ATL20-02_20181001010615_00370101_004_01.h5
Size is 316, 332
Origin = (-3950000.000000000000000,4350000.000000000000000)
Pixel Size = (25000.000000000000000,-25000.000000000000000)
Corner Coordinates:
Upper Left  (-3950000.000, 4350000.000)
Lower Left  (-3950000.000,-3950000.000)
Upper Right ( 3950000.000, 4350000.000)
Lower Right ( 3950000.000,-3950000.000)
Center      (       0.000,  200000.000)
Band 1 Block=500x500 Type=Float64, ColorInterp=Undefined
  Unit Type: degrees_north
HDF5 doesn't get geotransform or crs:
gdalinfo ATL20-02_20181001010615_00370101_004_01.h5 -sd 1 -nomd
Driver: HDF5Image/HDF5 Dataset
Size is 316, 332
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  332.0)
Upper Right (  316.0,    0.0)
Lower Right (  316.0,  332.0)
Center      (  158.0,  166.0)
Band 1 Block=500x500 Type=Float32, ColorInterp=Undefined
  NoData Value=3.4028235e+38
This is unproblematically NSIDC 25km south, there's no mix of poles in this
one. I honestly don't know what to expect from these files generally though
I get my hopes up sometimes haha.
I'll have to keep notes and explore more deeply with native HDF5 tools.
Cheers, Mike
Michael Sumner
Software and Database Engineer
Australian Antarctic Division
Hobart, Australia
e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240430/3217587b/attachment.htm>
