[gdal-dev] Test problem After Merge
Even Rouault even.rouault at spatialys.com
Tue Apr 30 10:41:32 PDT 2024
Andrew,
interestingly adding the debug traces I suggested to you to the GDAL CI
MacOS 14 build witch no longer worked turns out to reveal the exact same
issue as yours! (funny that I didn't even consider doing that myself !
interesting case where helping others actually is helping oneself :-))
_gdal.cpython-312-darwin.so was also linking against libgdal.so.34 (GDAL
3.8.5) instead of libgdal.so.35 (libgdal 3.10dev). The reason is that
this CI configuration uses conda-forge to install dependencies, and it
accidentally installed libgdal itself, instead of just its dependencies
(it add a "conda install --only-deps libgdal libgdal-arrow-parquet"
line, but I missed that libgdal *is* a dependency of
libgdal-arrow-parquet... )
Looking at the compilation log, I see:
arm64-apple-darwin20.0.0-clang++ -bundle -undefined dynamic_lookup
-Wl,-rpath,/Users/runner/miniconda3/envs/test/lib
-L/Users/runner/miniconda3/envs/test/lib
-Wl,-headerpad_max_install_names -Wl,-dead_strip_dylibs
-L/Users/runner/miniconda3/envs/test/lib -ftree-vectorize -fPIC
-fstack-protector-strong -O2 -pipe -isystem
/Users/runner/miniconda3/envs/test/include -D_FORTIFY_SOURCE=2 -isystem
build/temp.macosx-11.0-arm64-cpython-312/extensions/gdal_wrap.o
-L/Users/runner/work/gdal/gdal/build -lgdal -o
build/lib.macosx-11.0-arm64-cpython-312/osgeo/_gdal.cpython-312-darwin.so
So something in the Python extension building logic (conda
customizations?) adds this -L/Users/runner/miniconda3/envs/test/lib
where the "libgdal" from conda-forge is found, which apparently takes
precedence over the "-L/Users/runner/work/gdal/gdal/build -lgdal"
towards the end of the line, which is the bit that links against the
libgdal of the build tree.
For my CI case removing libgdal from the installed conda-forge packages
fixed the issue, but it would be nice if we could avoid/detect the issue
in the first place. If so, that would likely be some magic to add into
swig/python/setup.py.in. It might be tricky to do so though. Like
detecting -Larg in the linking options and looking for a
libgdal.so/dylib in them... ? Yuck. Or perhaps do some postprocessing
check that the resulting extension .so links against the expected libgdal?
Even
Le 30/04/2024 à 17:41, Andrew Bell a écrit :
> On Tue, Apr 30, 2024 at 9:18 AM Even Rouault
> <even.rouault at spatialys.com> wrote:
> Even,
>     Also try in a Python interpreter "from osgeo import gdal" to see
>     if the exception is more verbose. If your GDAL lib links against
>     libraries that are not in the default library search path, GDAL
>     command line utilities might still be able to find them, but
>     loading libgdal through the Python bindings might fail (at least
>     that happens to me on Linux, cf
>     https://github.com/OSGeo/gdal/pull/9783)
>     Also try otool -L on libgdal.dylib and on
>     _gdal.cpython-312-darwin.so <http://gdal.cpython-312-darwin.so>
> This was indeed the issue. I didn't think there was a version of GDAL
> in my environment, but it must have gotten in by error at some point.
> When the SWIG library _gdal...so was created, a dependency was created
> for the system-located library (version 34) rather than the one in the
> build (version 35). I'd have to do more research to figure out how to
> rectify this, if desired.
> Thanks for your help. The python failure message wasn't too helpful on
> its own.
> Andrew Bell
> andrew.bell.ia at gmail.com
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240430/7fa347ab/attachment.htm>
