[gdal-dev] gdal2tiles for floating point images
Michael Sumner mdsumner at gmail.com
Tue Apr 30 06:37:15 PDT 2024
Ok so my naive edits are clearly not enough, they still get written as Byte
so it's deeper in the target spec and spread across a few places I'm not
ready to get across yet.
Happy to pursue in the longer term though.
Cheers, Mike
On Tue, Apr 30, 2024 at 7:00 AM Michael Sumner <mdsumner at gmail.com> wrote:
> On Fri, Apr 26, 2024 at 5:37 AM lefsky--- via gdal-dev <
> gdal-dev at lists.osgeo.org> wrote:
>> I'd like to have a version of gdal2tiles that handles image types other
>> than uint8. Is there a reason why it doesn't handle those types of images?
>> It appears I'd have to modify the output format from png to tiff.  I have
>> never modified gdal source before and I'm wondering if this modification
>> (which appears straightforward to a naive user) hasn't been done before.
> Hello, it appears to be sufficient to add GTiff to tiledriver options,
> handle the file extension, and add an option to override the error/message
> that advises conversion to Byte:
> https://github.com/OSGeo/gdal/compare/master...dis-organization:gdal:gdal2tiles-nonbyte
> I wanted this myself as I'm working on a version of the tiling in an R
> package, and I'm not confident enough about it without being able to
> compare to gdal2tiles.py.
> It will need care to prepare it and merge into GDAL itself, with some
> thought about documentation, implications for html output (it's compleltely
> incompatible with the html produced I expect), and tests, but if you want
> to use it locally it seems ok and I'm happy to follow up off-list.
> Note that you can use VRT to reference such a tiled output for numeric
> data, I used it for a tiled global elevation source here (so if we fold
> this into GDAL that could be a nice option to include, VRT for reading as
> TMS):
> https://github.com/hypertidy/sds/blob/main/R/sources.R#L41
> Cheers, Mike
>> Michael
>> Michael Lefsky (He/His)
>> Home Location: HVHF+GH
>> Cell: 970-980-9036
>> http://www.researcherid.com/rid/A-7224-2009
>> *“for being prematurely, and worse, intuitively right — there’s a heavy
>> price. But for being wrong — no, not so long as you’re wrong in a pack."
>> Gary Brecher / Portis*
>> *I acknowledge that I live and work on stolen land. This is the land of
>> the Cheyenne, Arapaho, Ute, and Ocheithi Sakowin people. To learn more
>> about these nations, please visit;
>> http://www.utemountainutetribe.com/
>> http://www.cheyennenation.com/
>> https://cheyenneandarapaho-nsn.gov/
>> https://native-land.ca/
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
Michael Sumner
Hobart, Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240430/57124955/attachment.htm>
