[gdal-dev] gdal_translate shifted values
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Thu Feb 1 03:18:19 PST 2024
I used the gdal_compare script https://gdal.org/programs/gdalcompare.html
gdalcompare  st4_pr.2017092016.01h st4_pr.2017092016.01h.tif
and it reports three differences:
  *   Files differ at the binary level (normal, GRIB and tif are not the same)
  *   Difference in SRS (but they are alike, * IsSame() reports them as equivalent.)
  *   Difference in Dataset metadata key count ( ['AREA_OR_POINT'] added)
So if I read the report right the pixels in the files are identical. All I can conclude is that gdal_compare and your R script are doing something in different ways.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Furuya, Takahiro via gdal-dev
Lähetetty: torstai 1. helmikuuta 2024 1.53
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] gdal_translate shifted values
Hi gdal-dev, I am Takahiro, a student who is using gdal_translate.
I have an issue with gdal_translate and would like to ask a question.
I used gdal_translate to transform a NCEP GRIB file (downloadable from https://data.eol.ucar.edu/cgi-bin/codiac/fgr_form/id=21.093, or attached to this email) to GeoTiff, and compare those 2 data formats. The command I used is
>gdal_translate -of GTiff st4_pr.2017092016.01h st4_pr.2017092016.01h.tif
(The GRIB file I used was st4_pr.2017092016.01h, which can be downloaded from the above link by specifying "Begin Date/Time" to "20170920"/"15:00:00"  and "End Date/Time" to "20170920"/"15:59:59".)
Then I read the 2 data files in R and checked if the original value at a certain grid cell in the GRIB file remained at the same grid cell in the GeoTiff file, but the value was shifted by 6 rows (the value I checked was 9.75 [mm/hour] that was stored in index [100,86] in the original GRIB file, but it was shifted to [106,86] in the GeoTiff file).
You can see the Python script used for reading the original GRIB file here: https://bpa.st/ZNOSI
The R script used for checking the tif-translated data: https://bpa.st/WZLSY
The version of gdal_translate I used is 3.0.2.
Is this a known issue of gdal_translate? Or is this issue not supposed to happen (is this the mistake of my side?)?
Best regards,
Takahiro
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240201/81569b2b/attachment.htm>
