[gdal-dev] gdal_translate shifted values
Laurențiu Nicola lnicola at dend.ro
Thu Feb 1 03:24:49 PST 2024
Hi Jukka,
If GDAL shuffled around the pixels in that file, you wouldn't be able to notice it by comparing the GRIB and the TIFF, because both would be shuffled.
My suggestion was to convert the GRIB to a NC or even CSV using xarray, then comparing the GDAL output against that.
Laurentiu
On Thu, Feb 1, 2024, at 13:18, Rahkonen Jukka via gdal-dev wrote:
> Hi,
> I used the gdal_compare script https://gdal.org/programs/gdalcompare.html
> gdalcompare  st4_pr.2017092016.01h st4_pr.2017092016.01h.tif
> and it reports three differences:
>  • Files differ at the binary level (normal, GRIB and tif are not the same)
>  • Difference in SRS (but they are alike, * IsSame() reports them as equivalent.)
>  • Difference in Dataset metadata key count ( ['AREA_OR_POINT'] added)
> So if I read the report right the pixels in the files are identical. All I can conclude is that gdal_compare and your R script are doing something in different ways.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Furuya, Takahiro via gdal-dev
> *Lähetetty:* torstai 1. helmikuuta 2024 1.53
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] gdal_translate shifted values
> Hi gdal-dev, I am Takahiro, a student who is using gdal_translate.
> I have an issue with gdal_translate and would like to ask a question.
> I used gdal_translate to transform a NCEP GRIB file (downloadable from https://data.eol.ucar.edu/cgi-bin/codiac/fgr_form/id=21.093, or attached to this email) to GeoTiff, and compare those 2 data formats. The command I used is
> >gdal_translate -of GTiff st4_pr.2017092016.01h st4_pr.2017092016.01h.tif
> (The GRIB file I used was st4_pr.2017092016.01h, which can be downloaded from the above link by specifying “Begin Date/Time” to “20170920”/“15:00:00”  and “End Date/Time” to “20170920”/“15:59:59”.)
> Then I read the 2 data files in R and checked if the original value at a certain grid cell in the GRIB file remained at the same grid cell in the GeoTiff file, but the value was shifted by 6 rows (the value I checked was 9.75 [mm/hour] that was stored in index [100,86] in the original GRIB file, but it was shifted to [106,86] in the GeoTiff file).
> You can see the Python script used for reading the original GRIB file here: https://bpa.st/ZNOSI
> The R script used for checking the tif-translated data: https://bpa.st/WZLSY
> The version of gdal_translate I used is 3.0.2.
> Is this a known issue of gdal_translate? Or is this issue not supposed to happen (is this the mistake of my side?)?
> Best regards,
> Takahiro
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240201/0bdb8176/attachment-0001.htm>
