[gdal-dev] [EXT] Re: Unknown projection
Matt.Wilkie Matt.Wilkie at yukon.ca
Thu Feb 1 10:51:34 PST 2024
Thanks Even!
Matt
Sent: Wednesday, January 31, 2024 12:54
To: Matt.Wilkie <Matt.Wilkie at yukon.ca>; gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: [EXT] Re: [gdal-dev] Unknown projection
Matt,
surprisingly or not, the GTiff driver doesn't try to get the SRS from a .prj side car file.
So just do
gdal_edit.py 047_0001.tif -a_srs "$(cat 047_0001.prj)"
Even
Le 31/01/2024 à 20:22, Matt.Wilkie via gdal-dev a écrit :
Hello gdal,
I have a collection of aerial photos for which neither gdal nor arc pro recognize the projection. To my eye the .prj files look ok. Attached txt is gdalinfo v3.8.0 report along with the .prj. I manually formatted the below for readability:
PROJCS["UTM_07N",
    GEOGCS["NAD83-CSRS Epoch 2006 (7 Param+Vel)",
        DATUM["NAD83-CSRS Epoch 2006 (7 Param+Vel)",
            SPHEROID["GRS 80", 6378137,298.2572221010002],
            TOWGS84[1.0026,-1.9083,-0.5165, 1.288877171229702e-07, 8.998141921392988e-09, 5.376098909823645e-08, -1.18e-09]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-141],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metres",1]
Thanks!
Matt Wilkie
Geomatics Developer & Administrator
Environment | Technology, Innovation and Mapping
T 867-667-8133 | Yukon.ca<http://yukon.ca/>
Hours: 08:30-16:30, Mon-Wed: Office, Thu: Remote, Fri: Away.
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com<http://www.spatialys.com/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240201/3cb11cf7/attachment-0001.htm>
